1 - 3 of 3 Posts
So this is not what I wanted to do on my sunday. Went out to vacuum my truck and lifted the drivers side weathertech liner and it had condensation underneath it..sure thing drivers side carpet soaked. 2006 btw. So here some pics and videos I got... main question is....DO i have a leak? or do I have a clogged drain? Have had it for 4 ish years and never noticed an issue.
https://youtu.be/mktD34K_b2E
https://youtu.be/gXZlCFagVHU
Looking down the a pillar from a hole that is behind the fuse block on drivers kick panel...There is a sound block under the water as well as the foam stuff
Water is coming out of the top hole in the picture which seems to match the top mount for the fender in the picture below..When I removed the screw it was completely siliconed in...so im not sure how water got into it. I ran out of time to check anymore. Going to cover the hole and poor water on it again and see what happens.
The clip below sits right below where the hood release handle bolts to. I have no idea what it is holding on...
So last night I performed the TSB honda has for the passenger side and broke the clip off and drilled holes through the block and drained the water...but water never hit the ground.....so im not sure where it went maybe into the rocker.... this is how it looked after I drilled the hole and sealed it with seam sealer. Tonight im going to pour water into and see what happens.
2104 Honda Ridgeline SE
Only leak is down low. I am worried about the front drain for the mudguard. Currently there isnt a mudguard and the one I have is cut up to clear the tires. I am not sure where a hole should be on the sheet metal if there is any.
1 - 3 of 3 Posts
