DRL 1 Wire Mod
When the ignition comes on, all the lights are activated.
Notes:
- Pin 6 is closest to the passenger door.
- To access the connector, you just have to pop the bottom of the dash bezel off. You can then reach in and disconnect the harness from the light switch and cargo light switch.
- I simply jammed a single conductor hook up wire into the connector to jumper pins 3 & 6
Notes:
