My RL is a 2010 RTL with 105k miles. Check engine light engaged and code is P2185 (engine coolant temp sensor 2). My problem is that I cannot locate the second sensor. Sensor 1 is on the water pump housing and the Honda parts diagram shows sensor 2 as on the thermostat cover (see attached diagram) , but it's not there. Is anyone able to help me locate this sensor so I can change it out?
Thanks
Thanks
