I came across this thread. Basically says, Honda will not supply the full 14.4 plus volts for longer periods of time.
It applies to all Civics and Accords even from the mid 90's, I found other info indicating minivans being affected, I would not be surprised if the Ridgeline is affected also.
These kills the batteries faster, when running audio systems with a potential of over 1K watts of power. The report I read on line on different forums is the ELD or the ECM does not know the extra power being used for the amplifiers and the ELD not allowing the alternator to cycle longer periods of time while driving.
Since Civics have 90 amp alternators these suffer the most with people planning to power an audio system with over 1000 watts, having to replace the alternator and a bigger battery, when many other cars that do not have this ELD system HOnda uses, do not have issues killing batteries or needing better bigger alternators or batteries, running lots of power for the audio systems.
This issue can be tested easy I assume playing music (maybe powering a whole system with at least 500 Watts) and just watching when the voltage drops below 12.6 and and alternator kicks in, cycling between battery only power, alt and battery power to go back to 14 volts or more and dropping back when it should not.
Bypassing the ELD will keep that short cycle from happening many times that reduces the the batteries and alternator's life, running the alt for longer periods of time is not bad for the battery or alternator, the many short cycles is what affects both, according to what I read.
I am not a mechanic or know car electricals, not 100% that it is the issue with the trucks, not having 14 plus volts the majority of time while driving, limits potential maximum power from Car Amplifiers since most deliver over 20%, maybe up to 50% more power at 14.4 volts than at 12.6 volts.
If anyone is interested in searching this issue, test it and report it, please share your findings here on this thread. Even without using 1000 Watts, maybe this is the reason the batteries die sooner that expected. Honda uses this system to save gas, not sure the fraction of savings is worth it, maybe having an extra 3-4 years of battery life is better than an fraction of mile per gallon savings.
Some companies sell upgraded alternators that include the kit to bypass the ELD for Civics. Simpler but costly, no clue if the kits are availble for sale separate. I would not feel too confident making my own like shown on the thread below.
http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/
