161 - 180 of 210 Posts
1st post on the forum.... I bought a 2019 RTL-E (Nov. 2019) and since I've purchased I've had it in and out of the local service department shop (1 and now the other). I'm getting the Emissions EPS, VSA, Hill Start Assist, Trailer Stability Assist, Road Departure Mitigation System Problems. The shops are not able to recreate the errors after clearing them, but when I pick them up the errors return making multiple trips back and forth. I am able to clear the errors with my ODBII and force the errors when I engage the Honda Sense Lane Keep Assist (adaptive cruise control seems to work fine) come to a stop and let the vehicle rest for 10+ mins and restart it. If I do not use Honda Senses, then the emissions error comes and goes. Although, those errors returned after a week and were persistent when I dropped off my truck today. The previous shop recharged the old battery, replace it new, and replaced either the ECM or the Head Unit (I'm at work and I can't remember from the work sheet). Regardless they can't seem to recreate the errors (with techline on the phone). The only other thing the techs wouldn't have is my Pixel 4 XL phone (doubtful that's the cause). Sorry for the long rant, but has anyone else run into this litany of issues?
edit:
wanted to add ODBII fault codes P2123, P0453, P0641, P0651, P06a8
In a word YES. I have been dealing with the issue for over a year. (See my earlier posts) Still not resolved.
hello.
i thought i should chime in, unhappily, about my 2017 ridgeline and the emission code issues i have had. truthfully, i can't remember how many times i have gone to the dealer to try and get this issue resolved.
i have had the software update to try and fix it.
i have had my fuel injectors replaced.
i have had two catalytic convertors replaced.
i have had my top head and all related bits and pieces replaced.
the light just came back on three days ago.
i am on my way back in tomorrow to see what's the next thing they're going to do to try and 'fix' this.
i am losing faith in this truck - not matter what year. i have had two civics, one prelude, two elements and this is my second ridgeline.
i know this is going to sound corny but, we all work hard for our money and we're not getting our moneys worht out of these vehicles. i may have to switch to another brand.
garnet
vancouver
canada
hello.
garnet
vancouver
canada
When they replaced the injectors, what is the part number installed? If they are -305, I seen people on their 3rd set with that part number. The latest version are -315, so far they have been reliable. Might be too soon to give a verdict on the longevity of the -315.
2021 Radiant Red RTL
Wow, that is a troublesome course of events. I would probably bite the bullet and sell the vehicle if it is giving you that much trouble. I like the suggestion offered by @MtMan regarding the part number of the injectors. Hope it all works out for you without too much more aggravation.
the dealership is talking to honda canada and will see what they come up with. i am not holding my breath. i did forward them this forum address so they will know, that i know, that this is an ongoing issue.
if i sell it i still have to buy something else and i am sure i'll be out a lot of money.
sometimes owning vehicles is so awesome.
so...
i am going to pick up my truck tomorrow morning.
this time they replaced my fuel injectors - again (the number of the part i do not know but was assured they were the most up to date injectors they're installing)
they also replaced my high pressure fuel pump.
and did a B service because they had it on the lift. no charge - i guess not.
so we'll see how it goes from here.
I had Emission code problems with my 2017. Had it covered under the Federal Emissions Warranty. Check your owner’s manual. I had to point this out to the ”service manager“ but it was covered. 20000+ since and no problems
Discussion Starter · #170 ·
What was the problem and at what age and mileage did it occur?
The federal emissions warranty (2/24 except for the catalytic converters and PCM which are covered for 8/80) is shorter than the new vehicle limited warranty (3/36).
I ended up with the emissions system problem on my '17 with about 22k miles. Took it to the dealer yesterday and after about 1.5 hours of investigation determined there was a likely rodent chew in the evap hose. He had to use a borescope to see it, picture attached. Does not surprise me as we have a lot of squirrels around the house. The fix is to replace the entire fuel tank to the tune of just under $3k, which my insurance is going to pay all except my deductible.
404310
Anyone know if this evap hose would be just as vulnerable with a gas cap design?
Wait, ruptured evap hose calls for a fuel tank replacement?
I asked the service advisor several times if the whole tank really needed to be replaced. I can also say that my insurance company didn’t bat an eye at the price / resolution. I briefly spoke with the adjuster and she said they see rodent chews occasionally so I assume it’s not out of range to do this as a fix.
With all that said, I’m not a mechanic and only vaguely know about fuel and emission system components and how they work so it would not surprise me if there’s a different approach to resolve this.
Anyway, it seemed like it was hard to find the hole and it might be helpful to other owners who can’t seem to resolve their emission system problem issues, to check the fuel system components more closely. They did clear the warning lights and messages and so far it’s not come back on in the 40 or so miles I’ve driven it. Still need to get it repaired.
From a few years back
I forgot to provide an update.after 2 months of going back and forth (Honda Techs drove more miles than I ever got the chance to). they found a faulty junction box in the bed. Specifically near the tail gate so that when I used the swing gate, it would interrupt the sensor or the circuit causing the error. Mechanically, the truck was fine. Electronically, errors. Hopefully, you find your answer. I think I saw a similar issue in another post
Discussion Starter · #178 ·
Honda just came out with a warranty extension for the 2016 Pilot fuel injectors TSB 20-100. Will now cover for 10 years or 150,000 miles. I expect more announcements coming soon for the Ridgeline.
Hopefully, Honda will issue refunds for those who have already paid for this repair.
2017 RTL-E
I got the Emissons System problem warning lite last week and took it in to the dealer and was told it needed fuel injectors and fuel pump. Getting service done next Monday. Oh and I got the warning at 41,000 mi. It is a CPO truck and it has the 4 yr. 48,000 warranty, thank goodness. Also the lite was on for about 75 miles and then when off and hasn't came back on since.
2017 RTL-E
update Nov. 30 2020-got injectors and J-tube replaced but no fuel pump, I probably misunderstood, so it only took two-half hours. First problem I have had with truck,still a joy to drive and the ride is great.
