1 - 4 of 4 Posts
I have 2010 Ridgeline, flashing D , engine codes p0974,p0980 and0983, all are shift solenoids a, c, and d. control circuit high. Has anyone and this problem. they all came up at the same time after had not driven vehicle in couple of days and had no problems when I parked it but flashing D and check engine light came on as soon as I started it.
Get a new battery.
^^^^^ agree with this ^^^^^^
... and FYI, you can find interesting reading on this by searching "flashing D" in search box on blue stripe above. :)
Thanks! I replaced battery and it tested weak, but didn't fix. But started checking connection of all wires going to transmission found damaged wires at one connection. Wires are broken right next to connector, it is going to be difficult to reach/fix but will let you know. Thanks again for the help.
1 - 4 of 4 Posts
