Also, the oil level is fine as well as coolant level, timing components are still intact and there are no connecting rods sticking out of the block. It didn't over heat or make any strange noises before seizing.
Sounds like you may possibly have experienced a timing belt failure.... which can result in catastrophic failure, given interference engine. BUT... TB failure at that mileage is virtually unheard of, even though service interval is 105K miles..... AND, it typically wouldn't have resulted in an "instant seizure" as you have described. More likely damaged/broken valves & clattering before any greater colapse (e.g. broken pistons or ???). Although it doesn't sound like you may ever find out, it would be VERY interesting to us here to know the specific failure mode of this engine... in case you ever find out.Also, the oil level is fine as well as coolant level, timing components are still intact and there are no connecting rods sticking out of the block. It didn't over heat or make any strange noises before seizing.
