1 - 3 of 3 Posts
Have a 09 EX-L Ridgeline, would like to replace with another used engine. Which years number can I replace with?
2010 RT - Bali Blue
You can replace it with any Ridgeline motor from 2009 to 2014. You can also look into a similar year Acura 3.5L equipped counter parts Do know that you could keep the bottom end from other J35 engines, but the upper part and electronics could swap from your current engine to the donor. Also, keep it after the 2009+ years. Primarily due to the transmission bell housing design that is updated in the 2009+ Ridgelines.
Though few have done swaps, including JDM J35 engines (which I do not recommend), you should be able to do some research and swap the motors in.
1 - 3 of 3 Posts
