Erasing "servicing soon message"
1546 Views 8 Replies 7 Participants Last post by  henni
For the past two weeks every time I stat car, a message appears on dash.
"Service soon" !
How do I eliminate this without going to dealer.
Thank you all.
Pa
1 - 9 of 9 Posts
chances are your mm is telling you to change the oil and do other functions if needed, once everything is changed you can reset the mm, the instructions are in the owners manual.
On mine you turn key on and hold reset while the message is on (for longer than you would think) then when reset comes on select yes and you're done.
Problem is on my honda that procedure does not work.
Tried it 3 times.
Failure.
Please help.
2
I'm not sure what you mean by a TOURING RL. But this should work, on models without navigation.
Text Font Line Document
Text Font
"Touring" is a Canadian Ridgeline trim level. I believe it is similar to the RTL with navigation model in the US.
Thank you all.
The small text, "repeatedly press" was important.
Most persons mention, "press" !
It made the difference.
Love this forum for this added information and great persons driving Ridges
Pa
Yes and some of us down south drive them also as we happen to prefer metric data ;)
1 - 9 of 9 Posts
