See the thread below about another member who had a P0741 code. Unfortunately, they haven't follow up yet. I discussed some possible causes for P0741.
The torque converter clutch in a modern vehicle locks up shortly after you start moving in first gear and stays locked up most of the time. If the TCC is not engaging at all, your fuel economy will decrease, the transmission will run hotter, and the fluid life will decrease dramatically. You'll usually get an "Emissions System Problem" message as well because the engine will be turning faster than it's supposed to which can increase emissions levels above allowable thresholds.
If you're NOT getting an Emissions System Problem message, your fuel economy hasn't decreased, and you don't notice any difference in the way the vehicle drives or an increase in engine RPM while cruising on the highway, then most likely your TCC is working and the P0741 code is the result of the PCM's ability to detect that it's applied due to a faulty TCC pressure switch, clogged fluid path, or wiring problem. If that's the case, your issue may be resolved by replacing the external solenoid valve body instead of the torque converter and/or transmission. However, deeper and more careful diagnostics will be needed to make that determination and that's something that most dealers won't do - they'll just recommend a new transmission as a "catch all".
Since you can't be certain the TCC is engaging or engaging fully at this time, you run the risk of ruining the transmission. I suggest you go get a second and third opinion. You might get out for much less than the cost of a new torque converter or transmission.
I need the expertise of the group once again for a 2017 Ridgeline RTL-E with a little over 42,000 miles. When coming home today with approx. 120 miles to go the instrument panel lit up with two warnings: (1) Trans. System Problem along with a symbol of D overlapped with P and a dashed line...
www.ridgelineownersclub.com
