Hello Folks.. I'm hoping that someone might have an idea about this issue and point me in the right direction..
My problem currently is that when I put a fuse in the secondary fuse box for the trailer light circuit, my truck running lights come on and stay on until I pull the trailer fuse.. I have eliminated the factory trailer connectors (round and 4 pin) as issues as I had disconnected them at the upstream connector and the issue remained. Also.. when I test the trailer connector with my light.. I get power for the runnings lights... even with the fuse pulled. Sounds to me like I have a running light wire that had fused with the trailer harness somewhere.. When I put the fuse in the trailer circuit, it then back feeds my truck running lights.. My problem is where to start looking now !!! Has anyone run across this issue ? I suppose it might even be a bad relay somewhere but... I don't have a wiring diagram currently to start chasing wires and may end up giving up and installing an aftermarket trailer wire harness.. I just hate leaving things as they are, knowing that there is a wiring issue somewhere that might bite me harder down the road.. Any help would be appreciated !!
Regards,
Rod.
Regards,
Rod.
