I have googled this several times, but cannot find any threads in the forum concerning the same or similar problem:
It seems like I have some periodical connection problem between the shifter and the lights indicating which gear I am using. Parking fails from time to time, and when it doesn't lit I cannot remove the key. I wiggle the shifter a little, and there is a click in the door and key removes okay.
Reverse light rarely lits, and when there is no light on the dashboard, there is no reversing light in the rear of my car. Neutral is also mostly out of duty. P, 2 & 1 works 80 % of the time and normally will be okay if a move the shifter.
I guess there is a connector assembly which the shifter moves over, and maybe is a bit worn. Is this a known problem with Honda AT? What can I do to clean any connectors? Is there parts which is better to have replaced?
