RTL w/navigation. Got it June 26th. Off the lot with rear mud flaps, wheel locks and trunk carpet. Had pin stripes which I did not want and they removed them with no apparent problem.
The audio sounds good however it should have a mid control versus just bass and treble. The mids are a bit weak with some music. The subwoofer sounds like it has full range going to it versus low pass. The XM is cool but I can tell its not full CD quality as there is some ringing or compression artifacts.
The voice recognition can be quite amusing or irratating depending on your mood. It's funny when you ask for an XM channel and it turns down the A/C fan. And it should have a "your welcome" response if you say "thank you" - shouldn't it?? I think so!
Thanks to vert for his checklist (I found nothing wrong) - I have a VIN above 16000 and no leaks or wind noise. Had the dealer pre-check all these things and then drove home in the rain 140 miles with dry carpet (whew!)
