Had a little over 5000 miles on my BE as of today and I do a lot of towing so decided to proceed with an oil and filter change. I have a set of ramps which the truck drove up on easily and gave plenty of room to get to everything underneath. The oil drain plug is very easy to access and oil drains straight down without hitting anything. The oil filter is a little harder to get to but not that difficult. However, it is hard to get it out without at least some oil splashing down. I think the angle of how you get to it and remove it would help with that issue a bit so next time I will approach it a little differently once I get it loose and can just spin it off. If you tip the filter at all some is going to splash. But even with that, I had minimal drips and was able to wipe everything up with a towel easily. Putting the new oil is best done with a funnel as the oil fill opening is a little low to just pour freely without worrying about spills so I used a funnel with no problems. Cost of the Honda filter and Mobil 1 synthetic oil was under $35 total. Total time for the job was less than 30 minutes so I will continue to do my own oil changes.
