1 - 7 of 7 Posts
I have done some searches, including the forum regarding a fitted bed tray or mat. Everything that comes up seems to direct me to generic mats that can be "cut" to fit. Has anyone found anything the is an exact fit or very close to exact fit?
Thanks in advance for the help.
Just dropped it in.. no cutting required.
Question: does your DZ lift and flop @ freeway speeds?
Reason I ask is mine does.
But to be fair - another project in the works required shortening the mat by 4" at the cab end so it's entirely possible air swirl is getting under that edge causing levitation and wild flapping around. It got so bad I finally stopped leaving it back there unless bed floor protection is needed.
Mine doesn't as long as it is laying flat. There have been times where I flip it forward about 1/2 way to get into the trunk, if I forget to lay it back down flat it will start flopping around at 70mph +
1 - 7 of 7 Posts
