1 - 4 of 4 Posts
Help neither blinker on my driver side works I’m thinking it’s a flasher that needs to be replaced I can’t locate it passenger side rear and front blinkers work fine
maybe helpful to give your RL model year (gen 1 or gen 2)
I'd guess you have a faulty turn signal switch. No Ridgeline has a replaceable "flasher" - that function is built into the Multiplex Integrated Control Unit.
If you have the G1, what you need is the Turn Signal & Hazard relay. 38300-SDB-A03. This is the same for all MY of G1.
Is it intermittent or just wont work? When mine went bad, the Dr side worked fine, but the pass side was erratic and the rear was 'dancing' while the front had nothing. However, when using the hazard function, it worked just fine.
1 - 4 of 4 Posts
