I had to replace both inner CV boots. I have a 2" lift which makes that removal and re-install of the axle a real PIA. It required unbolting the tie rod and a lot of pushing the strut out of the way to get the axle into the hub. Obviously the movement of the strut was pretty small, a lot of effort for 3-4" of clearance to the right.
Prior to the replacement, the steering was responsive and I would say it was in the middle of the scale between an affordable sports coupe and an '88 Buick. Now, I would say it's moved down the scale about 3/4 of the way to the Buick. It's not pulling just floating feel in the steering. Makes me really nervous rolling around in a marshmallow.
What do you think? Can removing the tie
rod end from the arm and re-attaching cause such a problem? The ends weren't turned either direction.
