1 - 15 of 15 Posts
Around 1.5 - 2 grand when cruising I’m getting a jutter that makes my RPMs jitter up and down quickly. Sometime sit feels as if it’s starving for gas....like a partially clogged fuel filter. Any ideas?
2017 RL Sport AWD. 58k miles
Probably the fuel injectors sticking. Next up will be the emissions errors. Estimates out of warranty appear to be around $1500 with Honda maybe helping maybe not it appears.
Steve
I highly doubt its your fuel injectors. I would bet on TSB 17-025 and TSB17-026. Everyone jumps on the fuel injector bus like its bringing you to the "pot of gold". Take a look at the pinned conversation at the top of the board. I believe its the third conversation down. It has lots of info about these 2 service issues.
Any resolution? I am experiencing the same issue with my 2017 RTL-E. I first noticed it around 65K miles, and the odometer is now close to 72K. Mine occurs mostly around 45 mph and going up a slight incline. I have a service appointment later this week to have it checked out and have already told them to start with TSBs 17-025 and 17-026. If applicable, the service bulletins mention that these TSBs will be covered under an 8/80 warranty. Honda claims the transmission is not damaged by this judder but rather deteriorated transmission fluid. I had my fluid serviced around 40K and do not do any extreme driving or towing of any kind. I should know something by Friday.
Had it in today. They said the tech was able to duplicate it on a test drive and they updated the engine computer or whatever. . I didn’t ask how or what. We’ll see
Discussion Starter #9
Seems to be running better. Few hundred miles since the updated computer. No issues
Hopefully just a pressure switch or solenoid. I wonder if the tech did something wrong. Whatever you find out, please report back.
Discussion Starter #13
Verdict after a visit to the dealer today - Getting a new tranny!
Discussion Starter #14
Now the question is, will I be getting the same transmission or is there a new one being used in the 2018 and 2019 models?
Have the same issue, first answer was you need a new battery and to wait and see if it gives a code, second trip made the tech ride with, saw the issue, said it’s suppose to do that, Honda dealer is pissing me off. Anyone get a fix, they said they didn’t get anything on the laptop so won’t do the TSB
1 - 15 of 15 Posts
