And I thought the trailer hitch was hard, haha. Took me 6 hours but I got the fog light and bumper guard installed. Dropping the front bumber was easy. Then it came time to drill out the holes. Of course Honda has everything in metric and I have only SAE drill bits but it wasn't critical so I just selected the standard size that was close. Did the bumber guard first, no problem there, drill 10 holes and screw in some bolts and you're done.
Cutting out the hole for the fog lights was easy enough. Just need to go slow while cutting out the curves with a hacksaw blade, I used a open ended hacksaw blade handle. Cutting exactly on the line isn't too critical as the cover will overlap the cut edge by about half inch. Few more screws and they were attached to the bumper.
Then came the fun part of hooking up the wiring harness. That was a bitch but went pretty much as the directions described. The hardest part was with the connections to the lower fuse box. Two connectors had to come out in which you plug two wires from the fog light harness into. Each connector has a wiring lock on it which was quite difficult to figure out how to release and the directions did not give details. I'm not talking about pulling the connector out of the fuse box but rather the connector itself has a wire lock on it that must be release before plugging other wires into it. The big 18 pin one I used a screw driver to ply it off, it was sort of a tab across the whole width that flips up, hard to describe. The other small connector was different and you need needle nose pliers to pull out the white plastic part, not much to grab onto when in place so it took a bunch of tries to get it out.
Then the directions said to look for a 2 pin connector that was blue taped already installed near the headlight. There was no blue taped one for me, it was black taped which stumped me for a bit. After that it was pretty easy going, just alot of cable routing and zip ties.
The front bumper installed back just fine, just mind getting the lower and wheel molding in place before snapping everything back into place.
All said and done it was well worth it. Looks so much better now. I'll see if I can get some preliminary pics up tommorow. Now I'm down to two items left, the fender flares and the wireless backup sensors.
