1 - 8 of 8 Posts
Thinking about selling my 2006 has 82xxx miles Asking $13,500
Its been a good truck just wanting a change, I've kept this one longer than most...
below is maintenance records since I've owned it.
09/16/11 41,583 Purchase Truck
09/17/11 41,603 Tires and Alignment Michelin LTX A/T2
09/17/11 41,603 Wipers
09/28/11 41,989 Oil and Filter Change Wix 51356 Oil Filter (Air Filter looked new)
09/29/11 42,009 Tint front windows
10/05/11 42,172 Blower Motor Recall Service BLOW10-012
10/29/11 42,818 Sold Tonneau Cover and Vent Visors off Truck
11/12/11 43,145 Transfer Case Fluid Change (1 Quart)
11/12/11 43,145 Rear Differential Fluid Change VTM-4 (1 Gallon)
11/12/11 43,145 Transmission Fluid Change ATF-DW1 (3.6 Quarts) [1st for switch]
11/19/11 43,280 Transmission Fluid Change ATF-DW1 (3.6 Quarts) [2nd for switch]
11/19/11 43,300 Battery - Duralast Gold 8 Year Warranty [IPL & CKP Learn run]
11/25/11 43,476 Transmission Fluid Change ATF-DW1 (3.6 Quarts) [3rd for switch]
12/17/11 44,730 Oil and Filter Change Wix 51356 Oil Filter
01/22/12 45,803 Tire Rotation (front brakes 8/32, rear brakes 4/32)
03/31/12 47,608 Oil and Filter Change Wix 57356 Oil Filter
06/26/12 50,786 Oil and Filter Change Wix 57356 Oil Filter
09/09/12 52,697 Tire Rotation
10/21/12 53,870 Oil and Filter Change Wix 57356 Oil Filter
10/21/12 53,870 Air Filter
03/09/13 57,371 Oil and Filter Change Wix 57356 Oil Filter
03/12/13 57,466 Replace Radiator & Hoses & Coolant
06/16/13 60,161 Oil and Filter Change Wix 57356 Oil Filter
08/17/13 63,581 Oil and Filter Change Wix 57356 Oil Filter
09/02/13 64,022 Tire Rotation
11/30/13 66,533 Oil and Filter Change Wix 57356 Oil Filter
12/04/13 66,612 Wix Air Filter # 49119
03/22/14 69,930 Oil and Filter Change Wix 57356 Oil Filter
06/07/14 71,936 Transfer Case Fluid Change (1 Quart)
06/07/14 71,936 Rear Differential Fluid Change VTM-4 (1 Gallon)
06/07/14 71,936 Transmission Fluid Change ATF-DW1 (3.6 Quarts)
07/27/14 73,455 Oil and Filter Change Wix 57356 Oil Filter
07/31/14 73,480 Rear Brakes - Pads and Rotors
07/13/14 73,480 Brake Flush
10/18/14 75,705 Cabin Air Filter
11/23/14 76,463 Tire Rotation
11/29/14 76,604 Oil and Filter Change Wix 57356 Oil Filter
03/19/15 79,453 Replace Bank 1 Sensor 1 Oxygen Sensor
04/11/15 79,930 Oil and Filter Change Wix 57356 Oil Filter
04/26/15 80,288 Wix Air Filter # 49119
why can't this be closer to me?
Discussion Starter #8
7-3-2015 the truck is Sold, going to a new owner in Virginia, I hope they enjoy it as much as I did, great truck!
1 - 8 of 8 Posts
