All post 2009 grills will fit your 2014. Try this link and change year and model to see different styles...
Search 2013 Honda Ridgeline Bumper & Grille Parts
What's up ROC Brother? This topic is something I was interested in as well, especially after learning that there were differences by model year. Here's what I learned:
The 2006 "double racetrack" grille had no variations regardless of trim. In 2007, the RTX trim was introduced with a large honeycomb style blackout grille; this blackout grille also become the OEM optional grille for those that wanted to change the look of their 2006-2008 RLs. In 2009, a new "single racetrack" grille was introduced and came in two type, an all black racetrack for the RT trim and a chrome racetrack for the RTS and RTL trims. At this time, a new small honeycomb style blackout grille became the OEM optional grille for those that wanted to change things up. In 2012, the "sport" grille made its appearance with the new Sport trim; it was an all black grille with a four-row alternating sawtooth design; this grille became the SE trim's grille when it was introduced in 2014. In 2012, a new chrome three-bar style grille was introduced for all models except those that came with the sport grille.
Note: The 2006-2008 grilles will not fit on a 2009-2014 RL; you would need to change the entire front fascia if you wanted to do that.......
There were only a handful of aftermarket grilles for the Gen1 RL; possibly due to the low production numbers of the vehicle. There are some interesting examples on the ROC.
Strangely, yes the factory SE grille is selling for less than the OEM Accessory Grille. I too did not like the look of my 2009-2011 factory grille and prefer the blackout look of the other ones.McChizzle,
Outstanding! That was exactly what I was looking for -- a grill decoder ring! Much obliged.
I'm not sure why, but something about the chrome grill on my White 2014 RTL seems out of place. It is the only piece of chrome trim on the vehicle (not counting the Honda/Ridgeline badges on the tailgate.) All the other trim/accents are black. I like the white/black contrast of all the other trim.
So as I understand this, there is nothing to prevent me from swapping the blacked-out SE grill for my chromed RTL grill? And curiously, the SE grill seems to be the least expensive grill of the OEM options!
That's the 2009-2014 OEM Accessory Grille. It's probably being modeled on a Sport or SE trim which came with the black surround and black trimmed headlights.Okay folks, so which grill is this? Note honeycomb pattern, but with black surround trim:
So it seems to get the black "front grill molding" with the small honeycomb grill, you would have to purchase both the OEM optional grill and the Sport/SE "front grill molding" ??It looks like Honda calls it a "Front Grille Molding:" http://www.bernardiparts.com/Images/Install/2012_Ridgeline_FrontGrille_AII12020.pdf
Yes, but I'm not certain if you purchased the Sport/SE grille that you would not have to purchase the molding or not. More research is required.So it seems to get the black "front grill molding" with the small honeycomb grill, you would have to purchase both the OEM optional grill and the Sport/SE "front grill molding" ??
Thanks to links provided by @Carsmak, I believe we now know the answer to that question:Yes, but I'm not certain if you purchased the Sport/SE grille that you would not have to purchase the molding or not. More research is required.
Made my decision today. Attached Before & After Photos View attachment 186785 View attachment 186793
I like the black! Is that separate from the other grille or did you paint over the chrome?
It's separate, The Sport Grille comes with black surround, didn't paint anything. Still have the old grille with chrome surround ...
If you decide to do this yourself, be gentle with the clips that hold the front bumper cover to the vehicle; they're easy to damage and once they're bent out of shape they will not hold the bumper cover to the vehicle very well. If damaged, there is no way to repair or replace them, other than getting a whole new front bumper cover.If I'm reading this right, it looks like the Sport/SE grill and surround package is about $175:
https://www.hondapartsnow.com/parts...tl-s-special-edition-ka-5at/front-grille.html
