I had the factory ones on my G1 and they worked fine. HOWEVER.... The wind noise was noticeable and the fuel economy dropped by 1MPG with the bars only. With the Yakima box on, it dropped 3mpg. I think it is the price you pay for the utility.
Thanks for the feedback. Yeah, I'm well versed in the mileage and noise penalty from our experience with the Pilot. That is one (but not the primary) reason I plan to use aftermarket cross bars -- they can be quickly removed and stowed when not needed, leaving just the rails.I had the factory ones on my G1 and they worked fine. HOWEVER.... The wind noise was noticeable and the fuel economy dropped by 1MPG with the bars only. With the Yakima box on, it dropped 3mpg. I think it is the price you pay for the utility.
Thanks. When you say "buy it a la carte" I assume you are referring to the Thule system, not the oem roof rails?I've run with a Thule rack on top of mine for over 200,000 miles. You are probably aware, that you buy it ala carte and you don't have to have any cross bars. I do, because I use mine, a lot, but I have a wind deflector up there too.
I appreciate the input. I could not find any rails on Thule's website specific to the Ridgeline. Any chance you could get me a link or item# for the product that you are referring to? Thanks!Yes, Thule sells just the outside rails, crossbars are extra, as all their other "stuff".
No worries.Sorry, I had more than a senior moment. My Thule rack does not have side rails. It's just have 4 towers with bars across. I was thinking my bike mounts are the side rails. NOT!! Sorry to had thought that I had the answer to your issue.
ROC Brother, we meet again on another thread and hopefully I can help, at least a little. Your answer is no, you cannot purchase the OEM accessory roof rack without the crossbars. It's sold as one complete set. Honda does not recommend hauling anything that sits directly on the roof due to how they designed the roof structure. --Given we have moonroofs/sunroofs, the roof can't handle the same amount of weight than those without.-- However, if the weight is put on the side-beams, where Honda wants us to put the weight, our roofs can handle the load. So they purposefully do not offer their racks without the cross-bars and they have numerous OEM attachment systems for those cross-bars.... And if anyone knows the answer to my question about the OEM roof rails (can they be purchased without the cross bars?) I'm all ears. Thanks!
Yes it can be removed but it requires disassembly of the side-rails; so it would be a lot of work if you wanted to attach, detach, and reattach the OEM cross-bars. In other words, it would be a "one and done" type of thing and you can try and find/build the type of cross-bars you want to use/make. Here's a thread on how to remove the OEM cross-bar attachment points on the side-rails: http://www.ridgelineownersclub.com/...6578-how-remove-plastic-crossbar-holders.htmlMany thanks, McChizzle.
Alright then, that seems to answer the first question. So the follow-up question is whether those cross-bars can be removed from the oem rail assembly??? ...
Eurban,I have Yakima tracks mounted to aluminum hollow square stock that is custom bent to fit into the contours of the rain gutter. The square stock is bolted to the roof using the mounting studs for the factory rack. . .
That is good news - thanks! So aside from wasting money to buy the cross bars, it looks like the oem rails would work for me.Yes it can be removed but it requires disassembly of the side-rails; so it would be a lot of work if you wanted to attach, detach, and reattach the OEM cross-bars. In other words, it would be a "one and done" type of thing and you can try and find/build the type of cross-bars you want to use/make. Here's a thread on how to remove the OEM cross-bar attachment points on the side-rails: http://www.ridgelineownersclub.com/...6578-how-remove-plastic-crossbar-holders.html
