41 - 60 of 227 Posts
2014 Sport
The AC system on most vehicles uses around 5HP. I sure as hell can tell the difference in performance (highway cruising in particular) when the AC is switched on and off in my GenI. I would guess that most people could do the same . . .
I don't think that you could reasonably argue that the difference in humidity explains the absence of 3-5% improvement in power over a wide and useable RPM range in his real world test. That's stretching credulity.
Here's an S2000 video:
It makes a bit more power with the CAI (Don't know the brand) so for the performance minded its worth doing on that car. It aint a Ridgeline of course and neither is the old integra. . . .
I'm still waiting for the "factual information". Perhaps some of the early adopters of the GenII who decide to install the intake can provide some.
· Super Moderator
The discussion is great as long as we deal with intakes and not get into personalities. If in the end, we agree to disagree, that is ok too. But the discussion is certainly welcome as long as the discussion doesn't break down into a name calling contest.
After all, how else do we learn if we can't argue a point and either prove or disprove it?
Reactions: plex
great cant wait to hear more about it
-Does the engine sound change much after install?
-How does the intake sound at 70mph+?
-Faster off the line?
-Do you notice more hp/tq in any ranges?
I was looking under the hood and it seems like it will section off air from around the engine and mostly draw from air coming under the vehicle, in which case a slight scoop on the underside could be attached to really draw more air up to the intake... cant wait to get mine tomorrow and start tinkering :)
No - mechanics that know will tell you even a high efficiency A/C compressor can rob 10, 15, 20... even more horsepower as it's more than just the compressor - it increases the tension on the drive belt which then increases drag across the entire serpentine belt system.....
· Super Moderator
Be careful here. You don't want to inadvertently create an opportunity to hydrolock the engine. That will not be covered under warranty.
The G1 RL was designed to operate in 26.8 inches of water. I'm not sure if the G2 RL carries that design over or not.
http://www.ridgelineownersclub.com/forums/649642-post14.html
2014 Sport
It's not about flow as much as it is about air temperature - cooler - - thus higher density and increase in O2 content....
Stock setup draws air from outside the engine compartment. AEM system will allow more engine compartment air to be drawn in. . .It still MIGHT make more power but it won't be because it is drawing in cooler air.
2014 Sport
I'm not sure how a mechanic would know unless they dyno'ed for power loss? I'm sure it depends on the particular application. For what it is worth, Wikipedia says modern AC automotive systems use about 4hp.
When you are cruising on the highway (In a Ridgeline for instance) at 2K rpm or less your engine is only making a small portion of its total rated HP, well less than 100hp. A 5% drop in power is noticeable.
· Premium Member
If the G2 is anything like the G1. Once you remove the air box and lower half of the stock "Cold Air" intake. There is a rather large opening through the chassis/frame rail into the bumper that allows cool air to enter from the lower valence. My scan tool showed no temperature difference between my stock intake and my custom 3.5" w/6" K&N cone filter setup. It was reading ambient temps while driving.
2014 Sport
I believe you. In the case of the Ridgeline and many (if not most) modern cars the stock intakes already draw cold air. Aftermarket "cold air intakes" are not colder than stock. In some cases the area where they draw air FROM INSIDE THE ENGINE COMPARTENT may be at ambient, sometimes not.
Discussion Starter · #53 ·
I agree, the air won't be colder. It might actually be warmer than stock. I feel like the aem intake is just eliminating the factory components that keep the stock intake quiet, which will increase noise and airflow. That's a very restrictive factory intake, If you believe the aem dyno results.
So... did you install it yet? I think mine should get here today sometime
So JEGS just sent me an email saying they cancelled my order because the intake can't be shipped to CA. Balls.
· Premium Member
Do you have anyone that has an out of state address that you could ship it to? Someone who might be willing to ship it to you or somewhere closer that you could go pick it up?
I've had to do that a few times ordering stuff cross border. Lucky for me Calais Maine is only 1.5hr drive for me. :wink:
