61 - 64 of 64 Posts
Suspension lifts/leveling kits will not give you ground clearance. They will allow you to use larger tires. It’s the larger diameter tires which give you the additional ground clearance.
It still will not increase ground clearance. Measure the distance from the ground to your lower control arm before and after the install. There will be no change.
B.S.
When the time comes for new tires we will take the Ridgeline into Discount Tire, they will make their best suggestion with handling in the rain as being the top priority, we will have those tires installed and we will be happy until the next time! :D
Bill
hondopark I know your point you are correct but not correct. At "that point" you talk about will only lift the truck with taller tires. The only way to get a more clearance on any truck at "that point" you have to change A arms and a lot more but with the lifts out today you still get more clearance at other points thats why an alignment after any lift is major. And any one that off roads you know its all in your line pick and that bit more lift helps a lot from the stock set up.
61 - 64 of 64 Posts
