IMHO Honda's position is what the owners' manual says. I accidentally put in about 1/2 tank of E-85 in January. My 2007 RL threw some codes and disabled the ABS AND AWD. Luckily it didn't hurt anything.
Nice to hear that you can get non e. However I would venture to say that in most of the country it would either require a very long trip to a non e gas location and or paying a price for the gas that is double if not triple that of e10.Even 10% of the ECrap is too much for me. I use Ethanol free gas in all engines all the time unless I'm traveling and cannot find it, then I use an
additive and a little alcohol to absorb all the Ecrap water from the tank.
In Denver we have emission testing and only E10 is allowed for use in automobiles.Nice to hear that you can get non e. However I would venture to say that in most of the country it would either require a very long trip to a non e gas location and or paying a price for the gas that is double if not triple that of e10.
Basically don't assume that most those of us who buy e10 gas actually have a choice. We don't; count your blessings . . .
I was going to say all of this stuff, but I'm the idiot that put E-85 in my tank...Just a reminder...Don't put E-85 in your tank. If you do? Your RL will survive, just dilute at every opportunity.Adding about 3% by volume of anhydrous iso propyl alcohol
will provide a water tolerance of about 0.35% at 15C and about
0.2% at 0C, thus it's ability as a cosolvent is superior on
a volume basis, and far less temperature sensitive than
methanol.
Ethanol is between the two, with a 15% blend tolerating about
1% water at 15C. The best additives are the isomeric propyl
and butyl alcohols, and above them, the tolerance decreases
as the alcohols become less water miscible
Also, Alcohol is also used to absorb and dry water such as in your ear, etc. It absorbs the water to the point of evaporating it and /or providing a cosolvent for allowing the water separated from the ethanol to be reabsorbed into the gasoline thus providing less water settling in your fuel system and it mostly burned in combustion instead of remaining separated an your tank, lines. etc.
