1 - 12 of 12 Posts
OK, so what is the trick to shift into (R)?
On my RL I have to pull fairly hard on the shifter to go from (P) to (R), however since not much force is needed to go from (R) to (N) I find myself going from park to (N) and back up to (R) when I want to reverse.
Is it just a matter of me having to get use to this shifter? (All my other cars and trucks have had a floor shifter?
Well, in my case what I'm having to get used-to is the click from N to D. Short, odd little thing.
I suspect everyone will have some things they have to re-learn.
Me, too. I find the gear shift un-natural and requires effort. This maybe Honda over-compensating its transmission problems in Acura and Honda cars in the past 4 years.
When I first started driving it the shifter felt kind of rough like catching on something as i changed gears. So I tried not pulling back on the shift handle as far when changing and it felt alot smoother.
Same thing on the Pilot. You get used to it.
I have over 3000 miles on my Black RTLS Navi, and I have the shifter down pact. You'all will get used to it..................
Does the D3 button the shift lever take the tranny in and out of overdrive? Having the button depressed, does is make a difference going up and down hills? Thanks
Discussion Starter #10
The button isn't for overdrive, it is to lock in thr first 3 gears (of 5), similar to (1) and(2).
There is no overdrive button. I assume that the transmission CPU is smart enough to not hunt between 5 and 4 when towing?
I just got5 my Ridge yesterday. I noticed this at first, and was a little frustrated by it. However, by this morning, I think I have the hang of applying just enough pull to get out of Park, but not slip into Neutral.
It's a diferent feel, but you'll get used to it.
1 - 12 of 12 Posts
