81 - 85 of 85 Posts
I could have sworn I read above that even the lowly G1 Ridge had that inline filter? Does my reading comprehension suck that bad? ;)
The G1 trans filter is internal. The change procedure is as follows:
397977
Not really sure you want to change it....
Ok, so it is internal on the GenI. Where is it and how do you change it? Thanks!
FSM Page 14-299 details (as @speedlever pointed out) the process. From what it looks like, the transmission needs to come out of the vehicle and then the filter can be changed out. It is actually behind the Torque Converter (from the schematics), it seems.
Discussion Starter #83 (Edited)
Ran into two more threads on the Gen2's 6AT overheating:
Like the other threads, there are some members chiming in saying, basically, "me too."
Discussion Starter #84
Here is an interesting response to a Gen2 overheated transmission from a first-time poster/new ROC member on what Honda did when they reprogrammed the transmission to help fix the overheating program, interesting...
I had the same exact issue on 2017. It's not normal. I found a service bulletin on it. Basically tranny cooler is programmed wrong and let's the tranny fluid overheat and it breaks down. Mine had 40k miles on it. They reprogrammed the cooler to keep it lower temp and changed the tranny fluid and it went away. ...
I wonder what type of 'programming' they did. Unless it was something related to the cooling fans coming on at a lower water temp, to pull air through in lower speeds (??). The cooler is just a static unit, so is the warmer. I do not see (at least in the schematics) on where something 'electronic' is controlling the fluid flow. It appears that the fluid is active through the system when the vehicle is in motion.
81 - 85 of 85 Posts
