Here's all of the compiled, most relevant information for this. It may be handy if the OP consolidates the info in the first post. Hope it helps.
Genuine Honda Ridgeline G2 Tailgate Lock
Compatible with G2 models 2017 ~ 2020 (2020 comes installed)
Two parts are needed (costs are at the bottom)
Part-1: P/N 08Z07-T6Z-100D - Internal lock mechanism
Part-2: The appropriate matching color Handle (part numbers below)
P/N 08Z07-T6Z-110EL = White Diamond Pearl (paint code: NH-603P)
P/N 08Z07-T6Z-120E = Lunar Silver Metallic (paint code: NH-830M)
P/N 08Z07-T6Z-130E = Crystal Black Pearl (paint code: NH-731P, includes Black Edition)
P/N 08Z07-T6Z-140E = Modern Steel Metallic (paint code: NH-797M)
P/N 08Z07-T6Z-150E = Obsidian Blue Pearl (paint code: B-588P)
P/N 08Z07-T6Z-160E = Forest Mist Metallic or Pearl (paint code: G-537M or G-537P)
P/N 08Z07-T6Z-170E = Deep Scarlet Pearl (paint code: R-561P)
Tools Needed:
- Rubber Mallet or Hammer and Rag (to lightly tap the bulkhead cap [top edge of tailgate] for removal)
- T30 Torx Bit (for 7 Torx screws holding inner-side gate cover-panel. 4 at the top, 3 at the edge under the top cap [top edge of tailgate])
- 10mm Socket with Extension (for 2 recessed bolts inside the gate that hold handle, and 4 bolts for the lock)
- Phillips Screwdriver (4 screws in top cap of tailgate, also 2 screws to swap the Camera)
- Needle Nose Pliers (to help remove the rod/cable clips... I also needed it in my case to remove spring clip on my lock and rotate the latch)
- Hand towel or cloth for scratch prevention (to lay camera/new handle on while swapping)
- Magnet screwdriver or retriever (If you are clumsy & lose the bolts inside the gate, otherwise be careful)
Instructions
Honda PDF of full instructions [attached at bottom], they are detailed and good.
Installation Video Example 1:
Installation Video Example 2 From @Toolferone:
General info Video, Recoding a Honda Keylock:
Notes/Tips/Preparation:
- Kit includes 2 new, independent keys, before installing decide optionally to have your new lock cylinder recoded by a locksmith to match current keys [Approx. $25~$65]
- The lock you will be installing is a "manual only" lock, not actuated by electric locks
- Installation is intermediate-easy, takes about 1 hr. If you work at a slower pace & follow along with a video
- Mistakes I made:
- I have a tendency to over-tighten... do not over-tighten on these (except maybe the screws holding the camera if needed. The threads everywhere are aluminum and will strip pretty easy if you try to "crank em". The instructions say only 6lbs to 7lbs of torque. So don't overdo it.
- The locksmith I used to recode the lock made a very simple error putting the latch-post (where the rod connects) on 180 degrees wrong, I could not figure out why I couldn't get the handle installed correctly and it was an easy fix. just need to remove the retaining-clip (spring clip washer) and rotate the latch 180 degrees and squeeze the clip back on (pic below).
- I didn't trust the instructions. I was an early Ridgeline owner and fought with instructions on the bed cover, replacement bumper at one time, and some other things. So, when I thought the instructions were starting to get strange, I watched the video instead to see how the others did it. But this time Honda made the instructions correct and the steps are accurate. They even indicate the pounds of torque for the screws. They didn't indicate any of the clips by color, but you can still figure it out. (Hint: White Clips are for new rods, one Purple clip replaces the existing long-neck cable clip, and you will detach the yellow rod clip momentarily)
- Some other folks reported breaking the "NEW" 5mm Purple Rod Clip when installing, it cannot be ordered separately (the orig-old Purple Clip is too weak and will break if used)
- The new camera screw holes are not tapped very well on some units and are extremely tough to tighten enough to secure the camera, they may need wax, graphite or oil. Mine was just fine though.
- If you discover mysterious washers laying around, they were jarred out of the gate top rail-cap when removed (Middle Bottom) from @daktruckie99
Replacement parts (thease are only needed if you find you must repair something additional to the kit above, the kit you order has everything you need):
Replacement Torx screws: P/N 90108-SJC-A00 - If you strip those in the the gate cover panel:
Replacement Control Rod Synchronizer "A": P/N 74870-T6Z-A01 - This is only mentioned as an issue by one person with an install from a dealer. It is not necessary unless there was damage or an issue if the gate is tough to open.
Replacement Lower Cable: P/N 74867-SJC-A00 -This is only mentioned as an issue by one person with an install from a dealer. It is not necessary unless there was damage or an issue if the gate is tough to open.
Replacement Purple and White Rod Clips: Cannot be ordered separately at the time of this writing, they only come with the kit. Try not to break them.
Parts Retailers: (Cost-Lock, Cost-Handle, Cost-Shipping)
- HondaPartsNow.com ($32.47, $42.43, $10) - Least Expensive at the time of this writing
- OEMpartsource.com ($34.87, $39.19, $12)
- Conicellihondaparts.com ($36.51, $41.16, $9)
- Cheaperhondaparts.com ($37.10, $41.69, $14)
- Hondapartswholesaledirect.com ($39.37, $44.38, $12)
- Bernardiparts.com ($42.40, $47.65, $?)
- Amazon.com ($110, n/a, $)
- Collegehillshonda.com (n/a)
