jjm454 -
the reason you see two different sets of horespower values on the Ridgeline is, well, because there are (and, no, it has nothing to do with what color you have). The method by which horsepower is determined has changed - somewhere in the depths of ROC is a long discussion on this - you'll find it if you search on horsepower. Bottom line on the Ridge, it's got what its got. The numbers are just derived in different methods. As for the difference between the Ridge & the MDX, don't know - but it could be as simple as computer settings, or as complicated as different "internals." ("internals" is used here meaning all the stuff in the engine that makes it work that I will never claim to know anything about, other than when it works, all is good, when it doesn work, life stinks!)
-ridgeln
