1 - 4 of 4 Posts
I have a 06 rt, and I am having ignition problems. Key won't turn but I can start it by pulling the ignition switch and turning it with a screwdriver. Had the lock cylinder cleaned but still won't turn. I want to put it on a trailer and bring it to a mechanic but the steering is locked and the wheels are turned to the left. I disconnected the driveshaft and the back wheels will turn but not the front. Any help on how i can get it on the trailer or make the key turn would be greatly appreciated. Just don't know what to do. Thanks.
Put the front wheels on dollys.
Harbor Freight sells dollys for like 50 bucks.
Jack up the front and pull it onto the trailer with a winch.
Disconnect the front tie rod and turn the wheels by hand. EDIT:(I've never even looked to see if it has a tie rod) I guess if it doesn't then there has to be a way to disconnect the steering wheel from the part of the front suspension that is turning the wheels. Might need to remove a steering arm off the axle assembly by the brakes. (i'm trying to visualize it in my head), With the problems I've had with my truck, I've fortunately had no issues with the steering/suspension.
There is a little plastic cover on the column behind the steering wheel. It has a small slot on its edge. Use yur key to pop the cover and then insert your key into the hole you see. That should unlock the column lock and allow the shifter to move. You should be able to turn the wheel also and if in neutral, the parking pawl will not be engaged.
1 - 4 of 4 Posts
