Actually the Timing belt etc. was done around 91K, I missed it the first go thru as well:
4/23/2012 91,685 Lundgren Honda
Auburn, MA
508-832-6200
lundgrenhonda.com Engine compression checked
Engine/powertrain computer/module reprogrammed
Oil and filter changed
Water pump replaced
Timing belt replaced
Antifreeze/coolant flushed/changed
Drive belt(s) replaced
The Carfax is kinda light on services for the first owner, and I agree with the above poster that the documentation is light on other fluid changes besides oil. If purchased I'd suggest a complete fluid change so you have a baseline on the VTM4, Brake, AT, Windshield washer
act006
fluids etc. I was curious about the compression check as well, but what ever the issue was that must not have been an issue. I'm also curious why they just dial two-wheel alignment? It thought the standard was 4-wheel anymore. Otherwise looks like a pretty solid, nice RL. Good Luck.
