Yesterday I attempted the install for the turn signal relay modification with installing the .12 ohm 1W resistors. I have front and rear turn signal cree leds.
I soldered the .12 ohm 1W resistor in and then plugged it into the truck. *with incandescent front turn signals and led rear turn signals. It actually worked great! But I wanted to replace the front ones so I replaced one and checked it and then everything stopped. only the hazards would work so I replaced the other turn signal with the LED and it worked only with hazards and then not much longer nothing worked.
I took out the turn signal relay and noticed it had blown the .12 ohm resistor and also the primary box fuses #8 and #16 both being 15W Fuses. I checked the secondary under hood fuse box and the turn signal 7.5W isn't blown.
So I replaced the fuses and changed the .12 ohm resistor so nothing blown and nothing works.
As of now I have removed the resistor and put the original setup back on the turn signal relay box. I am not sure what I need to do next.
Is there another fuse I am missing?
