21 - 40 of 40 Posts
Mine were bad. just bought some Blue Magic the other day and after one coat and some elbow grease took care of a lot. I will need to do a couple more apps but don't know what the out come will be. Wish I took pics and choices you have vary a lot but so does tooth paste.
I have used Blue Magic also they also make the clear sealer protectant.
I've done the whole process and even added the protectant after and it was done. looks good for awhile and then it deteriorates quickly. I think you need to either spray with clear after or add a film to it. The original headlights come sprayed with some type of coating.
I just did this to my RL, I used 2000 grit sand paper because some spots where real baked in, but the other headlight cleaned like new with just Meguiars PlastX and some Meguiars Headlight Protectant to protect it from getting yellow again.
· Premium Member
Novus might work too. Great plastic cleaners come in 3 grades. Of course you should still apply a protective coat of some sort afterwards.
· Premium Member
Just curious in this discussion... all the dulling in my covers are on the inside not the outside...
Have never had much luck with any of the off the shelf headlight restore products. Most work when applied but after a few weeks headlights go right back to the way they were.
The only thing that I have found to work for an extended period of time is using a rubbing compound and my PC buffer or you can do it by hand but the buffer makes it much easier. Last a good 9 moths or so but I usually hit them up every six months or every other wax job.
I just used 3m kit. Comes with 3 grit disks and polish sponge with polish. Mine were very yellow/ cloudy. This kit was simple and looks exactly like new...very happy. I think on Amazon is $13. I got mine at advance auto. There is enough to material to do at least 5 cars. I used 1 of each disk. And sure I can use the a few more times.
2007 RTL Steel Blue
Once the protective clearcoat fails, the lenses will fade, no way around it. The restore products work great but require elbow grease.
I'm lazy. To quickly and easily remove the yellow oxidation, spray a cloth rag with any brand (or scent for that matter) bug repellant and wipe the lens. I don't know how, and I don't know why...but it instantly removes the oxidation. Takes 5 seconds per light. Then follow-up with a good coat of your favorite wax or polish. Kinda frightening that we spray this on our skin! I use a generic $3 aerosol can from Target. But I've also used "Off" brand backwoods scent, and unscented. Also used Cutter brand.
For ****s n giggles, I am experimenting on a friend's toyota to see which product keeps the lights from turning yellow again. She bought the Turtle Wax restore kit that comes with a product that you wipe on after cleaning to prevent future fading. We restored one headlight following the kit's instructions (word for word). Wiped the other clean with bug repellant. On the bug repellant lens, i wiped it after cleaning with BananaBoat 30spf sunscreen. Two weeks today, so far neither seem to be fading.
· Premium Member
2104 Honda Ridgeline SE
This morning a coworker mentioned her headlights were all yellow. We tried the Bug Spray method. Spray on, wait 20 seconds and wipe off. Unbelievable that this stuff is approved for use on humans. I wish I had taken before/after pics. The brand was Repel, Sportman's Max, 40% Deet.
2007 RTL Steel Blue
hahaha crazy, right!? I've used that stuff for days at a time when camping. Oh well. For the headlights tho, I don't wait. Just spray onto the cloth and wipe away. Glad it worked for you.
· Premium Member
I used Wipe New Headlight restore kit. I was extremely skeptical, but the shape of the headlight housings negated the risk of damage. I followed the directions and six months later, the housings are still very clear.
I got a good solid 2 years out of Opti-coat 2.0 on the headlights before I noticed any fading. Optimum has since come out with a headlight specific product and also reworked/renamed and doubled the price on their opti-coat so I can't say how the new ones work.
I've never tried their official headlight sealant; it is $70 for enough to do 5-6 cars so it isn't really designed for the do-it-yourself person. I like the opti-coat 2.0 because I could do the headlights when I did the rest of the car. And I could get 3 cars out of a single $60 syringe of it.
Having it parked outside all the time and mostly facing the same way the headlight that gets the most sun is just starting to fade again to where it looks a little cloudy at the 3 year mark.
I used the 3M kit that RPM90001 suggested and it was a quick, simple process that worked wonders. My covers hadn't yellowed but they were very fogged up on the outside. The came out looking like new and even after a year of road salt and everything else they held up great.
Just be sure that whatever kit you get allows you to use your power drill as a buffer, otherwise there will be a lot of elbow grease involved.
I did the Ridgeline headlights yesterday. I used the Meguiar's PlastX with the foam abrasive headlight pad I got with New Wipe kit. It came with New Wipe stuff I use on the OEM black hard Tonneau Cover to keep it looking new. I just keep using the dirty foam pad over and over. I keep in a small zip lock baggie.
I just put some PlastX on pad and rub back and forth around light take small microfiber towel cloth that came with kit to clean PlastX off.
The drill buffer came with the Meguiar's kit but never buffer pad.
I also put some old fashion original Rain X water repel on windshield and side windows of Ridgeline.
21 - 40 of 40 Posts
