1 - 20 of 77 Posts
This is really the only irritant I have with the G2.
On my G1 I loved to have the front windows up while the rear windows and sliding rear window were open. I opened the sliding rear window also because it reduced the helmholtz resonance created by having only the two rear windows open. When I do the 3 window method in my G2 the helmholtz resonance doesn't go away, it actually sounds like it gets worse. Has anyone else experienced this? Believe me, you would notice it. It sounds like a helicopter is in the cabin with you.
The moonroof and rear sliding window open does not have the same problem and of course all windows down is not an issue either.
ahhh i thought you were talking about the intake, it has quite an accordion and plethora of vanes in there :)
never mind a helicopter, more like a tornado !
Right, those would be resonators for the same purpose. I wonder if window visors help with this? I don't have them on my G2 like I did on my G1. Did some more reading and apparently this is becoming a bigger problem as cars become more and more aerodynamic.
· Premium Member
Oh GOD, the flash backs.... There starting all over again...
G2 Fake Mud
G2 Collectors Edition stored on blocks
G2 Fake water
:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
Discussion Starter · #8 ·
I find in most vehicles that running both windows down on the same side approx. the same amount takes care of the resonance/buffeting issue.
Right, I totally agree, but I'm not having any luck here. Having both rears down and the slider open should definitely not have any resonance (wasn't a problem in the G1). I'm not nit picky about things, but this one annoys me. Guess I'll just have to use the moon roof/rear slider more often.
Has anyone experience unbearable wind noise inside the cabin when both rear windows down completely? I'm thinking since there's no place for the wind to go and the back window is right there (no opening) you'll hear the loud noise. Any other ideas?
is it a buffeting that you are hearing or the whoosh (roar?) of the wind rushing by? I have have buffeting on several vehicles over my driving lifetime and some were unbearable and I have also had the wind rush blast in the driver window so strongly that I had to keep the windows up! Does it do it with the front windows down? You could try the window vent/rain guards, I don't know that they will definitely help but they could change the aerodynamics of the truck enough to stop the noise somewhat...maybe, no guarantees! >:)
Do you have a tonneau cover or cap? They also might smooth out the air flow.
Yes, there is more buffeting with the RL than other cars I have had. It can drive you nuts. The only way I have found to mitigate it when it happens is to open the driver window enough until it stops. I usually have the dog in the RL and when he is in the back with the window down opening up the other back window doesn't solve the issue enough. In other cars I would just open the opposite rear window enough for the buffeting to go away. I wonder if opening the rear window on BE's and E's just a pinch solves the issue.
Had a similar issue with my G1, but the G2 is definitely more susceptible. As others have commented, opening the back window or cracking the front windows usually stops it.
I have 17,000+ miles in. I've found the problem to be quite variable, apparently related to cross-winds. (That's the only thing I can pin the variability on.)
As someone else commented, I think that as aerodynamics of vehicles is calibrated to the gnats eyelashes, this is probably more likely to occur. The trade-off, I suppose, is better gas mileage. I'll take the latter.
Thanks for the suggestions and causes. It's definitely happens when the two rear windows are down. You can't hear yourself think! I had a 2011 Accord and never had the same experience. Wonder if this came up when the engineers were doing the wind tunnel testing. Going to have the door visors install this week so we'll see if this might help a little.
Pretty good explanation of what causes it
"Hermann von Helmholtz, the German physician and physicist who described this interaction, died in 1894 and was thus unavailable for comment."
· Super Moderator
Tilting the sun roof open help ?
If the rear window doesn't open, the model is low enough to not have a sunroof. :crying:
G1 for the Win... >:)
I think the small glass windows on the back doors cause a very annoying wind buffeting problem when the back windows are down. Over 45 mph and you need to open a front window.
This is the only gripe I have that I can't fix.
1 - 20 of 77 Posts
