I started installing the OEM tow wiring harness yesterday on my 2006 Ridgeline, and got everything under the dash and under the hood installed without a problem. I went to the left rear bumper, located the vehicle wiring harness tucked away, and cut the green tape and tried to pull it out.
It came out a little bit. I know I cleared what was held by the tape, and I reached up into the truck around the frame as far as I could and pulled as hard as I was comfortable pulling.
I was using both the factory Honda directions, and 1up5dwn's excellent pictorial how-to thread located here:http://www.ridgelineownersclub.com/forums/showthread.php?t=65345. My OEM kit came with a zip tie that the factory directions say is to fasten the vehicle harness into a spot in the frame about 6 inches from the end of the wiring.
Well I might be lucky if I can SEE 6" of the vehicle harness, I don't even think the end of the harness reaches the frame hole, so I need to find 6 more inches of harness somewhere from up in the nether regions of my truck frame/under the bed. Has anyone else had this problem, and how did you fix it?
Thanks for any help!
