Trying to track down a new oil leak, slow leak from front lower area getting all over a lot of things because it drips on frame parts and the shroud and flows around substantially. Have ruled out leaking from radiator lines and isolated the source to the area just above this metallic knobby connection pictured below (it looks clean because I cleaned it up but it blackens up and very wet), this view is from below, slightly passenger side of center, close to the radiator and cat, a pully and what looks perhaps like an alternator, leak could be from any of the bolts shown or the connector itself? I assume it is engine oil, although would not rule out AT fluid. Any help appreciated, thank you.
