1 - 20 of 25 Posts
Hello
I have read the other threads about VTM4 and Engine light problems but I think my situation is a little bit different.
I have a 2006 RTS with 109K miles on it. I keep up with the PMs and just recently, like yesterday in fact replaced a dead battery. I noticed on start up, after a few seconds, the Engine light came on and would not turn off. THen a few seconds later the VTM4 light comes on and stays on.
I checked fuse 21, relays, the vtm fuse in the front engine compartment, all are OK. I replaced the VTM4 fluid religiously according to the PM schedhule. What is going on?
Your suggestions are very much in need. Thanks.
Discussion Starter · #2 ·
PS two more things I forgot to add
1) I replaced the EGR valve
2) The VTM4 lock button does not seem to work or light up when pressed, R, 1, or 2.
Are you getting any DTCs?
See if this helps:
Discussion Starter · #6 ·
Thanks speedlever, unfortunately I do not have access to testing equipment and cannot get the codes, do you know of a way inexpensively?
Most autoparts stores will read the codes for free.
Alternatively you can pick up a BT code reader (Elm 327) from Amazon for about $15 and an android app call Torque Pro for $5 and read it yourself.
Discussion Starter · #9 ·
Thanks I will try Autozone tommorow.. Appreciate the advice!Have a good weekend, I will let you know what I found out, for the benefit of other members who may be having the same problem.:act035:
2011 RTL w/Nav
Hello
If a weak battery was in fact your problem, and you just replaced it yesterday, everything might still work itself out. Sometimes it takes a little time for the electrical system to get totally reset after replacing the battery. I had similar issues once, and the battery was finally replaced. My warning lights came back on one more time (after I left the dealerhip) but no more after that. Hope you have a similar result.
Most generic code readers will only let you into the engine controller and not the vtm
Well that's a bummer. How to know?
Just have to try it. But I know many the cheaper scanners will only do the engine controller. Even the mac/snap-on ones will not give everything a dealer would have access to. But still need to know what the check engine light is and if there is any possibility its related.
Will the scanner the autoparts stores use be able to do it?
The problem with trying is not knowing what you're missing. In my case, if I have no CEL/MIL, a test will show no codes which doesn't mean squat!
He says he has a CEL. The scanner will most likely only read p-codes which are generic. As you can see from the picture you posted the other Honda codes are different like XX-XX. I highly doubt there is a aftermarket that will give you the info a HDS will. But what seems to be your problem that you have no CEL?
I have no known problems. I'm just inquiring how I can test my OBD2 port scanner to know what it can and can't read.
Edit: actually I have 2 port scanners:
1) Garmin ecoRoute HD device
2) ELM 327 adapter (using a splitter off the OEM port for both devices)
1 - 20 of 25 Posts
