Thanks, it's not a shim but maybe the tension would do the trick for the up/down/side/side movement.
The shims were too big so I just wrapped the shaft in electrical tape (others talked about Gorilla tape but I had none). I just added a little at a time until it was snug enough to not rattle. Took maybe 2 minutes and 12-15" of tape total. Now totally OK!For those that bought the Bully referenced above, did yours come with any kind of shims? Mine moves around alot in the hitch, more than I prefer. I've seen reference to shims but there was nothing in my box nor the documentation included.
You can buy the same thing at Harbor Freight without the oval branding and reflectors: Hitch Mount Bumper StepI like that, but wish it didn’t have the big oval branding. I don’t do that kind of advertising.
But mine has REFLECTORS!! Ha!! LOLYou can buy the same thing at Harbor Freight without the oval branding and reflectors: Hitch Mount Bumper Step
Perfect - thank you! I’d never have thought of looking there.You can buy the same thing at Harbor Freight without the oval branding and reflectors: Hitch Mount Bumper Step
"SUPER BUMPER" has been my choice for more than 12 years and three RidgelinesReally wanted a bumper, but this one came with a step. I like it for $65. It’s about a 1 degree off so it slightly slopes to the right. I’ll fix that with a bit of JB Weld on the receiver to tilt it left slightly.
This is intriguing, but I think the impact would need to be within a few degrees of square on to be effective - 15° or so to each side. That, and I don’t care for the shape and texture for something being used as a step although adding more antiskid tape would help. But innovative! If they came up with a square profile design, I could be interested."SUPER BUMPER" has been my choice for more than 12 years and three Ridgelines
it absorbs impact and reduces whiplash by 22%. See website for an education on rear-end collisions and why body shops hate them. SUPERBUMPER.com
$200 is also kinda expensive.This is intriguing, but I think the impact would need to be within a few degrees of square on to be effective - 15° or so to each side. That, and I don’t care for the shape and texture for something being used as a step although adding more antiskid tape would help. But innovative! If they came up with a square profile design, I could be interested.
Well it would seem you are destined to learn for yourself. I cut the cover on my 2010 Ridgeline back in 2011, then went out and bought one. Have had four of them, I give them as presents also.This is intriguing, but I think the impact would need to be within a few degrees of square on to be effective - 15° or so to each side. That, and I don’t care for the shape and texture for something being used as a step although adding more antiskid tape would help. But innovative! If they came up with a square profile design, I could be interested.
Websites like that appeal to a certain type of person. I'm not that type, so regardless of their product (which like HeavyDuty mentioned, doesn't seem well designed), I'd be giving them a wide berth.See website for an education on rear-end collisions and why body shops hate them. SUPERBUMPER.com
Whatsoever a man soweth, that shall he also reap.'Websites like that appeal to a certain type of person. I'm not that type, so regardless of their product (which like HeavyDuty mentioned, doesn't seem well designed), I'd be giving them a wide berth.
Slightly weird, but not surprisingWhatsoever a man soweth, that shall he also reap.'
Galatians 7.
Now there's something I hadn't thought of. And I have way too much electrical tape laying around.The shims were too big so I just wrapped the shaft in electrical tape (others talked about Gorilla tape but I had none). I just added a little at a time until it was snug enough to not rattle. Took maybe 2 minutes and 12-15" of tape total. Now totally OK!
Do you have any business affiliation with this company?Well it would seem you are destined to learn for yourself. I cut the cover on my 2010 Ridgeline back in 2011, then went out and bought one. Have had four of them, I give them as presents also.
SF
B6
Not with my Bully. No issues at all with accessibility. Plus looks as though it came as standard equipment with the truck.I was considering buying a hitch mounted step but wonder if it would interfere with use of the trunk since at 5' 7" I would need to stretch forward to lift and place an item (especially heavy ones) in the trunk. Is this an issue for anyone?
Good point. Wouldn't want to increase the chance of a back injury from lifting while reaching out further from the body.I was considering buying a hitch mounted step but wonder if it would interfere with use of the trunk since at 5' 7" I would need to stretch forward to lift and place an item (especially heavy ones) in the trunk. Is this an issue for anyone?
