1 - 9 of 9 Posts
My first weekend with the new Ridgeline. Hopefully I have successfully attached pictures to this message.
I transported two loads of patio pavers, 700 lbs. each. I just used a couple scraps of OSB plywood to protect the bed from scratching.
I strapped my homemade bikerack into the bed. I made the rack to fit inside of my CR-V, but it works well with the Ridge as well.
If you are concerned with scratching your bed, did you put anything under your bike rack? :confused:
The rubber tires on the bike will scratch less than the wood of the bike rack. :rolleyes:
Discussion Starter · #4 ·
Thanks for the tip, but the base of the bike rack is not to prevent scratching, it is a functional part of the rack. The front tires of the bikes slide into the "rack" and the weight of the bikes on the base helps to keep the rack vertical.
Your Ridgeline and your lawn look just like mine :) It looks like you're getting as much rain as we are in Central VA. My lawn is toast (although the weeds are nice and green). Anyway, your truck looks great.
Discussion Starter · #7 ·
The Ridge is a very tight fit in my garage. I was shocked when I first brought it home. I knew it was bigger than my CR-V but wow does it fill up the garage.
1 - 9 of 9 Posts
