I remember the old days of turbocharged engines:I have to wonder about the service requirements, reliability, and longevity of the turbo'd engines. Will that likely be adversely affected?
Following a quick thought, I can't think of a single model Ford currently sells that doesn't come standard with a turbocharged engine or offer one as an option. That honestly caught me off guard - I had no idea. I believe it's safe to say that turbochargers are quickly becoming the rule rather than the exception.Ford has certainly turned that corner successfully.
You are almost completely right! The Transit Connect lacks a Turbo at least in the USA. Every Ford overseas has a turbo bolted on to the diesel version. I've driven several of the Turbo Diesels on overseas trips and love them.Following a quick thought, I can't think of a single model Ford currently sells that doesn't come standard with a turbocharged engine or offer one as an option. That honestly caught me off guard - I had no idea. I believe it's safe to say that turbochargers are quickly becoming the rule rather than the exception.
According to Ford's website, even the 2015 Transit Connect is available with a 1.6L EcoBoost, so it appears Ford is using turbocharged engines across the board.You are almost completely right! The Transit Connect lacks a Turbo at least in the USA. Every Ford overseas has a turbo bolted on to the diesel version. I've driven several of the Turbo Diesels on overseas trips and love them.
Had the 9-3 turbo as well, took less than 3 seconds to go from 60 to 100 mph... loved that car. When I traded it in, I was getting around 32mpg with 130k on the odometer.This is awesome! Wife had a 9-3 back when with a turbo 4. Good mileage and incredible power and never knew it was a turbo 4. Honda could probably do twice as well.
