I'm up in the air on this deflector, looks great, but I would like one that I could remove when I wanted to. Honda instructions show having to use 3M protective tape, no problem with the tape except when you remove the deflector the tape is there, won't look too good. For those of you that have installed the deflector does the mounting bracket have any clearance between the tape on the hood and the bracket, or is it a snug fit. I guess if there was some clearance then you could put the 3M tape on the bracket and not the hood, but still doesn't solve the problem with the outside mounting nuts that have to stick on the hood. Any ideas on this.
trainman
trainman
