2020 RTL-E with about 15,000 miles. Driving to Nashville to attend the NWTF Convention and about half way through the trip, started to notice a slight flutter on the driver's side up near the windshield. Speed was 74 MPH. Was a windy day and did not at first think it was a problem. On the return trip, did not notice any unusual hood movements. When purchased on the test drive, got it up to about 95 MPH to see if I could induce hood flutter. Did not see any, so assumed Honda had remedied this problem. Removed the backing underneath the hood after the trip and noticed that the adhesive between the hood and the frame had failed at several applications on the driver's side. Took it in for service the next day and notified the service rep that I had hood flutter. His response was that he has never heard of it before. Someone else came over and verified this was a known issue with a published TSB. S/B 17-083 applied. Have not tested it yet but hopefully the 3M Ultrapro Autobody sealant (60100-TG7-A90ZZ) will do the trick. I guess the learning point from this is that over time, the autobody sealant can fail and cause the hood to detach from the frame. Feel this is a band aid fix and the problem is with the design of the hood. If the fix is to redesign the front end and add 32 lbs of steel hood, then I am all in. The problem with that is that I know what I have (no water leaks, 2021 wheels, and everything seems to work other than the hood). I am not sure what I will get with a newer version except out of pocket costs and a wireless charger that does not work. Will report if the fix works.
