I would start troubleshooting by removing the trailer from the equation.
Did you drive on D3 only after the noise started as a troubleshoot or did you drive D3 for a long period prior?I put it in D3 several times and in all but 1 occasion the noise stopped. On that one occasion, the truck downshifted and I heard the noise at 3K RPM.
Thanks everyone.
I use OEM fluids and washers. It looked like the washer had not been crushed at all. I think the last service was at the dealership around 10k ago. The one in Fort Smith truly deserves the title of stealership. They did a timing belt for me once and 300 miles later the pulleys fell off. They weren't going to fix it until I threatened to call customer care.Yeah, that's definitely not a normal looking rear diff mag plug. I rarely see anything on mine. Who did the last service on your rear diff? I assume you use OEM fluids?
I have to wonder if that rear diff has been leaking for a while. It holds about 3 quarts of VTM-4 fluid.
I can change the thread title if you want. What would you like it to be?
If the honda ends up running fine even after driving 600 miles on an empty dif while towing a car, people should use this as a freakin testimonial. Keeping fingers crossed and hopes high. :smile:
Since you said the drain plug wasn't even finger tight, it sounds to me like the shop forgot to tighten it after the last service. But if it was leaking, I would hope you would have noticed the fluid drops. I doubt it dumped the fluid all at once, but ya never know.I use OEM fluids and washers. It looked like the washer had not been crushed at all. I think the last service was at the dealership around 10k ago. The one in Fort Smith truly deserves the title of stealership. They did a timing belt for me once and 300 miles later the pulleys fell off. They weren't going to fix it until I threatened to call customer care.
Anyway, My guess is the extra pressure on the VTM system from the towing caused it to push the plug out? I really don't know how long its been leaking, but there were no spots on my driveway before I left for Texas, but after I got here there was a spot on the driveway.
Change the title to whatever you may think would make this easiest to find for someone in the same shoes. The sound doesn't seem like its coming from the rear. I thought it was the transmission because that's where you hear it from.
On good note:
I filled it with fluid. Drove it around a bit to mix it up and hopefully pick up some particulate. Sound was much quieter and seemed to be gone after about a minute. Going to change the fluid in it tomorrow again and see what the magnet picked up. If it's mostly clean I'm going to test out VTM and see my damage. If it's not then I will start again.
