1 - 3 of 3 Posts
I recently added an Air Horn, inline, with my factory horn. I didn't have any problems, until I had to lean on it hard a couple of days ago.
Here's the scoop; When the fuse blows (20A), it also effects the Stop Lights,
the ABS system, and the TBS system. When you shut the engine down, it locks out the shifter, so you can't shift into drive. If you don't have a fuse handy, you can get back in motion by pulling the little tab on top of the steering column
out and placing the key down in it. Then press the brake pedal and shift into neutral and start the engine. Once you replace the fuse, which is in the box under the hood on the passengers side, you will, be back in business. Use caution on your way to the Auto Parts Store because you won't have any stoplights.
1 - 3 of 3 Posts
