It appears that the carpet must be removed to replace a broken floor mat hook.
Can anyone confirm this?
I bought the replacement part (83650-SHJ-A01), but from the way the two parts attach together, it seems the carpet needs to be pulled.
The top part, with the actual hook on it, has two posts that clip into holes in the base plate, which is located under the carpet. The only way I can see to detach the top part is to pry on the little retainer clips on the bottom of the base plate (which is again, under the carpet) - see arrows on last photo.
