41 - 54 of 54 Posts
Ended up with the Maxspiders myself - very nice. And the rears fit better than I was expecting after seeing some complaints. Truck was a week old when they arrived - glad to have the carpet protected, especially since the weather is already starting to get sloppy.
Sorry I missed your original question from 1 month ago. Just now saw it. The back mat was a real bear to get installed correctly, mostly because it grips the carpet so tightly, makes it hard to align perfectly. I found that it was way easier to align with two people, one on each side. The under the seat mat however fell right into place. Had them over a month already and they are truly genuine carpet savers with 99% coverage.
Now that winter has arrived I am happier than ever with my selection of weatherTech. I added the front and rears along with the rear seat under storage tray and the cup holder for my i-Phone. The lips on my mats keep water, mud and slush contained entirely within the mat and they clean up nicely as needed. Nobody beats the fit and finish of WeatherTech and yes... they are not cheap but are IMHO worth every penny.
As always... Opinions and YMMV.
(y)
I put husky's in the back as they look to have the best protection and 3d maxpiders in the front as I see them more , they fit as well if not better and I like the look
I have been studying this way too long now. In my opinion there are no clear winners based upon these comments. I will research a little more but I am leaning towards the Husky product at the moment. Any particular source beside the factory? Is there an alternate? Thanks!
I've got the Maxpyder 3D front mats and the Husky rear mat. They seem to fit well, albeit tight, but temps have not been above freezing here for a while, so they are pretty stiff (installed less than a week ago). Purchased from Amazon.
I went with the Maxliners and they have been fine. There are some on here that have stated with various floor liners that I had a problem with this on the front and this and that didn’t fit properly. Might be an issue with either the way they were made, designed or the current mold they were using. There will always be a better fit than what I got or someone else bought, but I will live with what I chose at the time. All of them have pro’s and con’s to each one. Look at what is available and what works best for you. with so many alternatives, it isn’t always easy basing it on what someone stated on a forum. See if you can find someone that is actually using the brand you are looking at, and some you may not have even considered. Look at those if you can before you lay out your hard earned cash!
LOL, OEM here for years on all my Hondas, i like the softer thicker rubber it flecks nice when removing. Im in the bush a lot, plenty of mud and snowy boots for years, its not a deep tub, never had issues with my snow shoes on with plenty of snow on them :). Why do some need some special floor mat tub thats like a piece of computerized rubber hardwood floor. Over priced and over rated, whats the rest of your truck like.
Just received and installed Maxpider Kagu mats. Fit very nice with excellent coverage. Rear cargo fit is a little off where the small tabs cover the area between the cargo and passenger area but this shouldn't be an issue and could resolve as the mats relax into the space. Overall very happy with fit and time will tell about durability and wear. 2019 RTL.
I just did the Huskys front and back In a 19BE. Put them in and they fit as designed but one or two edges didn’t fit perfect. So I laid them out in the sun for several hours (Tucson). They became much less rigid and very easy to work with. Then back in the truck and I sorta pushed on them in a couple of spots to better fit. The next day I went to check and they had ended up being perfect fit.
I have the Husky mats front and rear as well. Very satisfied.
There is virtually no exposed carpeting, and combined with the smooth surface of the mats, makes the truck very quick/easy to vacuum and keep clean.
To me, a big drawback of the Maxpider Kagu mat is the rubberized and textured surface.
It has to be more difficult to clean when you get mud/salt/dirty water on the mats, as it gets ground into the dimpled surface and doesn't easily wipe away from the rubber.
Stock Honda rubber mats, easy to remove, hold up well over several years, colors match, and by the looks of it are cheaper.
I went with the Honda All Season Mats High Wall on my new 2020 BE. Fit like a glove and seem hefty and heavy duty enough to last a good while, plus they look good and say Ridgeline on them. Now I'm looking at something for underneath the back seat, but have not decided yet. Currently eyeing the Cargo Tray (08U45-T6Z-100). Picked up a Honda cargo net last week for use in the bed and I also want to add running boards eventually. Accessories = $$.
I have the Maxpider Kagu liners (full set) in my Ridgeline. While I have not had them very long, they don't seem to be any harder to clean than the WeatherTech liners I had in my previous Frontier. And I like the grip of the rubberized surface; it's not as slick as the WeatherTechs.
I guess time will tell.
Based on the materials and design alone, the Maxpider mats would be more difficult clean/maintain by default.
  • A smooth surface will be easier to clean than one that has thousands of dimples/recesses.
  • A harder plastic surface will be easier to clean than a rubberized surface.
Someone on here mentioned finding gum (or something similar) ground into their Maxpider mat and was never able to fully remove it.
That would not be a problem with Husky style mats.
41 - 54 of 54 Posts
