Ignition Coil Question.
1606 Views 1 Reply 2 Participants Last post by  S.T.U.V
Does anyone know what the difference is between the 2008 ignition coils and the 2009 ignition coils??
The part numbers are different but look the exact same.
I have a opportunity to use 6 used coils from a 2009 on my 2008 to help diagnose a weird shake/rumble idle problem Im having.
Just want to throw them on to rule out the coils being the issue or not.... but not sure if them being a different part number will really matter at all or cause problem?
1 - 2 of 2 Posts
Check your motor mounts. More then likely the issue. Physically they could be the same internally idk. connector Plugs might be different. 99.9% of the time a bad coil throws a miss fire code. And it is rare for a coil to go bad.
1 - 2 of 2 Posts
