I bought this cheap AX-ANR1000 to try and reduce radio noise.
http://www.sonicelectronix.com/item_26831_Axxess-AX-ANR1000.html
Wiring connections are as followed:
BLACK = (-) GROUND
RED = (+) 12 VOLT OUTPUT
GREEN = (+) 12 VOLT INPUT
Can someone tell me where to wire the red and green?
I think red will go to the 12V ignition ACC red wire on the harness, while the green should attach to the blue power antenna wire.
I'm not experienced with wiring. Please confirm or correct me if I'm wrong. I have a feeling that the green wire should be connected somewhere else?
Thanks in advance for the help.
BLACK = (-) GROUND
