Actually, I had intended to install it today. I was just unpacking it to make sure I had everything and all of a sudden it was on the truck. Seriously, the most difficult part was unpacking the boxes (two). The items were so well packed even UPS couldn't damage the tonneau.
This has to be the easiest top I have had to install and use. I had a solid tonneau on my Nissan and it was a pain. Whenever I needed to haul anything it took two strong men and a boy to get the thing off! The Retrax is so easy to get out of the way that I anticipate very seldom needing to remove it. If I'm carefull, I can lift it out myself, it's that light.
I did need to go to the hardware store to get T-50 Torx socket to fit my ratchet. I had the T-40 already. That was the most time consuming part of the operation. I cannot get out of that store without hearing six new jokes and a bunch of bull from my friends there. Always enjoyable, however.
I have only discovered one problem. It involves, to no ones surprise, the bed extender. There is a nylon stop on the drivers side of the Retrax rail that is supposed to keep the top from overextending but it keeps the extender from flipping over while in the rear position. The front position is pretty useless with the Retrax in place. I think I can use a cutoff wheel and shorten the stop and the bolt that holds it in place. I think I'll check with Randy at ReTrax before I do.
One last item. I read the instructions and it had provisions for all sorts of adjustment to assure a tight fit. I found mine fit perfectly right out of the box. I was really impressed. This cover is of a quality that lives up to that of the truck it's mounted on. To the folks at ReTrax...nice going guys!
