Interior water leaks
115022 Views 540 Replies 168 Participants Last post by  whiskerbiscuit
Moderator's note: More than a dozen threads on interior water leaks were merged on November 20, 2021. This is the correct thread to discuss interior water leaks. There is also a poll on the subject. Please use the poll thread only to answer the poll.
bought my G2 on June 29, 2016. Since then my floors have been wet after most rains. First time i brought it to Honda they said it was an improperly sealed grommet in the floor behind the driver seat. The second time i brought it in they had it for over a week and told be the body seam behind the cab was improperly sealed. Less than a month later the carpets were wet again and i brought it back. Honda has had it now for over a week. I was told that the body seam by the right front wheel well was improperly sealed also. The service manager told me the machine sealing the seam improperly sealed the seam with caulk. LET THIS BE A WARNING TO EVERYONE WHO HAS AN EARLY PRODUCTION G2, CHECK UNDER YOUR CARPETS. MAKE SURE YOU ARE NOT GETTING ANY WATER UNDER THEM.
Reactions: 1
501 - 520 of 541 Posts
Made an account just to post this - a water leak issue that took several months to diagnose and about 5 minutes to fix. I haven't seen this described anywhere else in my searching so I wanted to get this out there so hopefully someone else experiencing the same issue will find it.
The issue: water would be found in the cabin interior under the front passenger carpets after extended heavy rain.
The fix: there is a shared drain area in the frame used by both the sunroof and cowl where crud (like dead leaf bits) can accumulate and end up blocking it, which makes water overflow into the interior during periods of heavy rain. Cleaning this should resolve the issue. (see pictures)
The diagnosis process (long, but for the sake of anyone searching for this issue or partially along this process themselves)
The issue did not occur during extended periods light rain, or brief periods of heavy rain.
Vehicle was kept outside, surrounding area was lightly wooded (this actually does matter). For consistencies sake, we kept it parked in the same orientation each time once we noticed the issue.
After we first noticed the water, we opened up the interior molding to see if we could find where the penetration occurred. There was no obvious entry (e.g. no water just pouring in) but there was definite moisture inside the front passenger A-pillar, from the base (near the floor) all the way up to the speakers in the A-pillar (which is as far as we could get a hand)
Given how high up the water was, we started checking areas above that level, primarily the sunroof and the front windshield. We did notice a lot of dead leaves lodged in the front passenger cowl (between the windshield and hood), so we cleaned those out, thinking that water might be overflowing from there to a gap somewhere. We then took the garden hose and saturated all the seams (door/windshield/roof rail/cowl/engine bay/etc.) in the whole front passenger area
We couldn’t see any obvious water penetration either.
We next noticed that after heavy rain there was standing water in the front passenger sunroof tray drain line (the area below the sunroof that’s intended to channel any water that makes it through into drain tubes). It would drain within two or three days after the rain stopped.
This obviously indicated some sort of problem, but didn’t make sense – if it was clogged, how could it also be leaking?
We tried putting a partial cover over just the sunroof (because the whole vehicle covers are a pain), which didn’t fix the issue either (though the sunroof has less water in it)
We finally ran a tube attached to an air compressor down the sunroof drain line to blow it out, which mostly just ended up blowing the water out of the top or blowing the air compressor tube out of the drain line. The drain line didn’t really drain any faster, but we did notice some slight water dripping near the front passenger wheel molding.
Finally we tried pulling the molding off that area, and lo and behold a ton of water and a bunch of dirt/crud fell out!
The root cause: over time, dirt/crud from the outside can flow through the drain lines from both the sunroof and cowl into a single area hidden by the body molding. Eventually this can clog up, and overflow into the interior of the vehicle. Cleaning this just requires popping the molding off and cleaning anything that has accumulated out. Picture below shows the area with the molding (which just pops off) between the front passenger door and wheel well.
Tire Wheel Automotive tire Tread Automotive lighting
Reactions: 2
Ever since Honda put sun roofs in, those drains often need attention. On my '94 Civic, I enlarged the bottom of the drain tubes to let most of the debris flow out.
2
Another update...after finding and fixing leaks on the driver's side months ago and NEVER having water on the passenger side in over two years, I thought I was good. Being in central Florida, where it rains almost daily during the summer, a leak would be pretty evident. For months, there's been no evidence (and I've checked) but a few weeks ago, I opened the door and smelled that damp, mildewy smell that meant lots of water inside. It was so bad that at first I thought a window had been left open but only the underside of the carpet on the passenger side was very wet. I removed the outside trim on that side and checked and it turns out I had the exact two leaks as on the driver's side - a trickle at the upper corner/side of the window and a much bigger leak into the trim clip holes. I made the same 'fixes' to the window and trim clips as I had done on the driver's side. The truck was recently outside during hurricane Ian with no water inside after the storm. So (maybe) my leaks are finally fixed...until the next one shows up that is.
I replaced the foam 'washers' on the three inner clips shown here. I also added a lot of butyl tape along the window and between those two things, no water is getting in.
Wheel Tire Automotive tire Bicycle tire Tread
Here's a typical old foam piece (black) and one I used to replace it. I suspect other owners' leaks are because of this same issue. It just takes a few minutes to check and a little longer to fix but it's not difficult.
Wood Rectangle Material property Font Metal
  • Helpful
Reactions: 4
The leak on my BE was fixed in May and the truck had been dry since. I drove for about 75 miles in steady rain on Halloween night. The next morning I got in the truck and immediately noticed an odd smell. The rear carpet was soaked, again, more on the pass side than driver's. Dropped the truck off to the dealer tonight. They have been great to me, hoping they can nail the leak this time.
Is this issue with all model years? I have a new 2023 BE.
Reactions: 1
The issue can occur in all model years and is purely random. Every owner needs to remove the rear doorsill molding and check underneath the carpet for moisture.
So if it is wet where does water come from and what is the fix? Is this common or is it a small percent? Last if Honda knows about this why does it keep happening?
The water comes from various locations - most often through a missing or insufficient portion of seam sealer on the rear of the cab, but sometimes around the back window or a pass-through. The fix is to apply seam sealer or reseat/replace a grommet/gasket or reinstall/replace the rear window assembly.
If this poll is anywhere near accurate, as many as 1 out of 5 Ridgelines might leak - possibly even more if everyone actually inspected for water leaks since they aren't always apparent. The good news is that complaints about water leaks have slowed suggesting that the situation may have improved.
That's a good question. None of us know. I'm sure that Honda doesn't want Ridgelines to leak, but the design and/or assembly process might be to blame and are too expensive to fix so it keeps happening. Complaints about water leaks can be found on nearly every make and model of vehicle ever sold. First generation Ridgelines leaked occasionally, but second generation Ridgelines appear to be much more prone to the issue. Since it's been going on for years, it must be cheaper for Honda to fix leaky vehicles than to address the root cause which may solve itself for the next generation.
Reactions: 1
I been checking my 23’ regularly to the point I broke one of the sill clips.
Reactions: 1
There’s a few little things about the Ridgeline that bothers me, such as the wireless charger and the auto high beams, but not really a big deal to me. But this is a big deal to me, it’s very irritating that they have this problem. they know it and they just continue to allow it to happen. It really softens my confidence in my vehicle, and especially in Honda, who I thought was a top notch auto manufacturer. Disappointing for sure.
Reactions: 1
Well, I will be checking mine. I don’t think I’m going to check it too often after my initial checks. It’s been raining here since I bought my truck pretty regular, so I’m going take the water hose and soak the rear window and check. If it stays dry, I’m going to assume it’s sealed and I’m not going to continue to check it after that. I would think if it’s going to leak I should know it after checking at one time after a bunch of rain and a good water hose soaking. If I were you, I would go to the Honda dealership and ask them to repair those clips, that’s absolutely unacceptable that you have to check your vehicle so often your trim is breaking. This is irritating.
Well, I had to leave for an appointment so it’s been raining for a few hours. Plus it rained hard recently plus, I soak my window, I only check my driver side rear carpet, but it’s dry. Hopefully I’m a lucky one. I still need to check my passenger side. I’ll do that when I get done and return home.
Reactions: 1
Glad to hear it. Be certain to check underneath the carpet padding, as the water will not wick up through the padding to the carpet.
Thanks for the heads up, I did lift up the padding so I was on the metal floor….. I just checked the passenger side. It’s dry too thankfully. It’s still amazes me that Honda knows this problem exists it has not fixed it. I just don’t get it. I’m so thankful at least up to this point it’s dry.
  • Helpful
Reactions: 2
Same result for me.
Dry as a Mormon.
Hopefully this issue is in the rear view mirror of the Ridgeline
I havent had a vehicle I like as much as this one since my new then 07’ H3.
Reactions: 2
Same result for me.
Dry as a Mormon.
I agree, I am really enjoying this vehicle. And I also agree I hope it’s in the rearview mirror as it should be. I’m not going to continue to check, the way I look at it if it has a leak between all the rain and soaking my rear window I should know it. So for now I’m just going to forget about it. I’m still a little bit disappointed that I had to worry about it at all, especially since it’s been a problem for a few years. That’s really hard for me to understand.
We finally received our proceeds from the Whirlpool dishwasher settlement that began 4 years ago - $97.35. A nice unexpected Christmas present.
Reactions: 1
I should have read this before I got started trying to diagnose and fix water getting under the front passenger carpet. After some heavy rain, the underside of the front carpet was wet and I assumed it was a similar issue as the back - badly sealed seam, foam washer that was no longer sealing a hole, etc. but it turned out to be a much easier fix (like ridginald said above but mine is slightly different). My driver side sunroof drain was clogged and the water that should have exited near the front (driver) tire couldn't and water was getting in the cabin at the passenger front corner. I guess there was simply too much water to all get out. This would happen with a heavy rain or when I filled the area at the front of the sunroof with water. Online, you'll find suggestions to use weed trimmer line to 'snake' through the drain from the top. That worked for me but took several tries because the trimmer line is not very stiff. After fixing the clog, I saw the idea of using a speedometer cable and ordered one for about $9 on Amazon. It seems like it will work better as it's basically a tiny version of a plumber's snake - flexible and stronger than trimmer line. Anyway, cleaning out these drains might be a good thing to do occasionally - maybe every oil change or so.
What I did on my old Civic was take the inner fender/liner loose, find the drain, & cut the tip open, did all four. I have not seen what the Ridgeline drain looks like, but I'll ASSume there is a restriction at the end just like every other Honda I've repaired for this
Personally, I'd rather not have a big hole in my roof.
I had the leak on the rear passenger side a year ago. It was repaired under warranty. They checked the entire rear cabin for more leaks at that time and found none. 1 month ago, the left rear leaked. Same issue. A bad seam. My concern is that these seams are "gapping" or similar as you utilize the vehicle. I am not sure how that is possible given that these seams are spot welded. The only conclusion I can come too is that the seam sealer deteriorated. It is a 2019. It was out of warranty but the dealership covered the cost. Of course a few small clips holding the trim on the interior of the vehicle and the bed trim was damaged in the process.
